Sonarr and SAB nzbd no longer friends
Hi, I had my unraid server up and running for 5 years, then an update crashed all the dockers and I had to reinstall.
I reinstalled the binhex versions of the above dockers with emby.
Sonar and radarr communicate with SaB and Sab downloads the files… but they stay in the downloaded folder.
Sonarr and Radarr are no longer moving them to their appropriate folders and renaming them.
It was a while ago I originally set it up all so I am probably forgetting a setting or something.
Please help.
Version
4.0.13.2932
Package Version
4.0.13.2932-1 by sonarr
.NET
Yes (6.0.36)
AppData Directory
/config
Startup Directory
/usr/lib/sonarr/bin
Mode
Console
More than likely related to your mounts.
Check
https://trash-guides.info/File-and-Folder-Structure/How-to-set-up/Unraid/
https://trash-guides.info/File-and-Folder-Structure/How-to-set-up/Docker/
